TwinTurbo.NET: Nissan 300ZX forum - FOUND IT... thanks every one, it WAS under the hood..
Subject FOUND IT... thanks every one, it WAS under the hood..
Posted by Hoppy2 on April 07, 2010 at 8:13 AM
  This message has been viewed 86 times.
In Reply To If you smell gas, find the leak! Don't depend on your nose posted by zellamay on April 03, 2010 at 06:13 PM
Message the soft line that connects from the stainless 300 dergree line to the FPR was leaking on the fpr... looked like the clamp failed as it wouldnt tighten or loosen, getting a new clamp and hope the smell is gone.. I found it by leaving key on and following all lines, I moved this line and fuel sprayed out.. could this have caused my stumble? I was going to run codes but disconnected batt to do some other work.. DUH..
2 Z's in the making!!
