TwinTurbo.NET: Nissan 300ZX forum - Re: vacuum lines ok for the egr?
Subject Re: vacuum lines ok for the egr?
Posted by Roundabout136 on April 06, 2010 at 4:55 PM
  This message has been viewed 85 times.
In Reply To vacuum lines ok for the egr? posted by Brett@AwesomeZ on April 05, 2010 at 07:42 PM
Message The vac lines from the valve to the solenoid were changed during the throttle body coolant line bypass. When I was having this issue, the vac line connected from the solenoid to the throttle body vac connection was not connected, found that corrected it and the problem was still there. I really thought it would solve it but turns out not.
As far as the fuel issue goes, i pulled the plenum today and found a leaky injector, so i'll be replacing the o-rings on the injector Thursday.
I'm really stumped on this EGR issue. When we pulled the plenum there was a small amount of fuel around the EGR things that go inside the plenum, sorry i forget what they're called. I highly doubt this could be causing the issue.
