TwinTurbo.NET: Nissan 300ZX forum - Fuel smell is indicative of a leak. Rough idle is usually a
Subject Fuel smell is indicative of a leak. Rough idle is usually a
Posted by Eric(FL) on April 06, 2010 at 3:51 PM
  This message has been viewed 162 times.
In Reply To Re: I question fuel smell in the cabin as a sign of a posted by paul1994 on April 06, 2010 at 02:51 PM
Message bad injector but could also be a bad coil or any number of things.
First thing I would do is find the source of the fuel leak as zellamay said as this is very dangerous. Second, I would pull each coil connector individually to see if the cause of your rough idle is due to any particular cylinder not firing.
If you isolate a particular cylinder that is not firing, swap the coil with one next to it and see if the missing cylinder moves with the coil. If the same cylinder is misfiring, you likely have an injector problem.
later,
eric
