So I check Fuses/Relays and fuel pressure and that was good. With the in fuel line disconnected I started the car and it started with good idle until gas ran out in the fuel rail. So I assumed it could be dumping too much fuel in motor. So I proceeded to pull the fuel rail out to check for leaks. No leaks found... Any ideas?
Need Help with fuel system issue.. - keu2812:48:28 04/06/10
