| Message |
that connect from the top of the bulkhead to anything fuel pump related. Feed and return on top, and a short feed with 2 double spring clamps. All clamps and hoses were tight when I checked, but of course I will double check to eliminate the variable and since one of the clamps on top looks to be non-OEM (OEM would be a philips fuel clamp, and not the flathead worm clamp that I found on my return line). I was looking for other ideas regarding my weird cranking issue but I will start with inspection of the hoses and checking pressure.For future searchers with NA-TT swaps in 2+2s...make sure the short hoses that connects the FP to the bulkhead is seated as far in as possible. You will notice that's it's basically this hose that holds the FP to to bulkhead, and the FPs height is determined by how much you adjust the hose. Make the FP as close to the bulkhead, and not to the fuel tank, as possible. If you don't do this, the strainer on the bottom will hit the baffles and bottom of the fuel tank, and will eventually damage the strainer (you will notice the recoil effect of the strainer, that will be eliminated with constant banging on it if you left the hose in a position where it would force the fuel pump to hang lower than normal).
