TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel pressure issue? and some TT fuel pump voltage notes.
Subject Re: Fuel pressure issue? and some TT fuel pump voltage notes.
Posted by njz on April 05, 2010 at 9:50 PM
  This message has been viewed 79 times.
In Reply To Fuel pressure issue? and some TT fuel pump voltage notes. posted by ZiNnYc on April 05, 2010 at 09:13 PM
Message The Voltage is about right, 8V low and 12V Hi (NA FPC)
As you stated, check your fuel pressure at the filter out 36 vac on 44 vac off if your pressure is low you may a hose leak in the tank causing the pump to run longer to build pressure.
