TwinTurbo.NET: Nissan 300ZX forum - Fuel pressure issue? and some TT fuel pump voltage notes.
Subject Fuel pressure issue? and some TT fuel pump voltage notes.
Posted by ZiNnYc on April 05, 2010 at 9:13 PM
  This message has been viewed 89 times.
Message My TT fuel pump (NA FPC & NA modded ECU) is sputtering on
me.
It was purchased from a member with low miles. Upon
installation, the car will turn over but only after the 2nd crank
after exhausting a full 1st cranking of 3-4 secs (cold start).
Warm start, the car cranks over after a sec of cranking,
sputters a little (very low idle for half a sec) then becomes
normal.
ZERO issues with starting beforehand (even on cold start, car
would crank after half a sec, and full power no sloppy idle)
Fuel pump voltage is at 7.5 at idle, WOT is battery.
(For reference, it was discovered that the fuel pump exhibits
load voltage at 4200-4300 RPM when acceleration is applied
gently. Pedal to the floor from idle, WOT throttle is exhibited
at 3000-3300 RPM. RPM taken from average of Blitz i-color EBC
& stock tachometer.)
Im going to try new fuel clamps immediately on the bulkhead
assembly first, then move on from there (test fuel pressure up
front, etc.). Any educated thoughts on how to proceed?
