TwinTurbo.NET: Nissan 300ZX forum - Re: Re: So fuel pressure is good too? - and how's the
Subject Re: Re: So fuel pressure is good too? - and how's the
Posted by Brett@AwesomeZ on April 05, 2010 at 7:50 PM
  This message has been viewed 124 times.
In Reply To Re: So fuel pressure is good too? - and how's the posted by D0ctor on April 04, 2010 at 10:27 AM
Message Well, that's pretty normal just for turning the key on, the pump
will only run for a couple seconds. It doesn't make much sense,
you've got spark and injectors are pulsing. I'd say double check
the connectors on all your sensors, your ground on the intake
and make sure all your intake piping is good and tight, no vacuum
leaks etc.
A lot of times after rebuilds you'll find that hoses and stuff that
were just fine before are now split and leaking, like pcv hoses
and the one from the IAC to the balance tube.
www.awesomez.org
