TwinTurbo.NET: Nissan 300ZX forum - IIRC with your setup you'll only get two speeds out of your
Subject IIRC with your setup you'll only get two speeds out of your
Posted by Eric(FL) on April 05, 2010 at 2:28 PM
  This message has been viewed 113 times.
In Reply To That doesn't seem to be the reason. posted by ZiNnYc on April 05, 2010 at 01:28 PM
Message TT fuel pump, idle setting and high setting. Perhaps because the pump is running on high all the time is causing the louder than normal noise.
In order to get the intermediate speed you'll need a TT FPC and run an additional wire from the ECU to the FPC. I can't remember what pin on the ECU or FPC you'll need but I know I've seen it posted here before.
later,
eric
