| Threw in my TT fuel pump last night. Issues: The infamous whine is present. Like all noise interpretations, some have said that this whine is to be expected, and some even say that they don't have it on their conversion. I'm currently running it on a NA FPC and NA ECU. I will be measuring voltage tonight, but here is just what I discovered as new. Pump was swapped correctly (NA housing TT pump in my 2+2 tank). The startup pressure noise has SiGNIFICANTLY increased, and it does not crank well on the first 1-3 tries. It will turn over afterwards (my remote start doesn't work anymore because of this). This along with the huge hissing noise in the rear of the car, and I just may wellbring it back to an NA pump until I have higher HP goals. Another small issue is that the gas reading is off, but I'm figuring the float got stuck somewhere. Any thoughts on the cranking issues?
