TwinTurbo.NET: Nissan 300ZX forum - Re: Base idle set correctly...now VERY low cold idle
Subject Re: Base idle set correctly...now VERY low cold idle
Posted by Andy_M on April 05, 2010 at 9:50 AM
  This message has been viewed 428 times.
In Reply To Changed IACV and fixed vacuum leak - now idle issue posted by Andy_M on March 31, 2010 at 12:51 PM
Message OK, base idle set per procedure on a warm engine. Car runs great and idle is perrrrrfect on a warm engine.
Cold is another story. Engine will not idle high enough to stay running without me attending the throttle for a few mins. Idle tries to drop to 600 or so and the engine will not stay running. If I keep my foot on the throttle and keep it at 1000 rpm for a few mins, it warms up enough to stay running at a very low idle. BUT...if I put it in gear the idle drops a LOT more than 50 - 70 rpm and the engine will stall if I'm not careful.
The exhaust also seems to smell stronger than it used to when cold. The ECU is showing no error codes however, and the car RUNS better than ever when warm.
ideas ??
Andy_M
atmorris@ptd.net (home)
