| Subject |
An easy gauge check |
| Posted by |
ConVerTT on April 03, 2010 at 11:02 AM |
This message has been viewed 92 times. |
| In Reply To |
not sure if I read that correctly, but sounds like you have posted by LJZTT on April 03, 2010 at 05:20 AM |
| Message |
Pick up a cheap boost gauge - 40 0r 50 bucks from your favorite auto parts store and a plastic T connector and a 3 or 4 ft length of vacuum hose. Tap into one of the vacuum hoses that connect to the balance tube at the back of the engine. Run the vacuum line under the hood over the cowl and through your window so you can read it. Drive car .... Report back with results
| Follow Ups |
Post a Followup |
