TwinTurbo.NET: Nissan 300ZX forum - Almost sounds like the fuel pump is being turned on
Subject Almost sounds like the fuel pump is being turned on
Posted by jzack on April 04, 2010 at 5:06 PM
  This message has been viewed 65 times.
In Reply To Re: So fuel pressure is good too? - and how's the posted by D0ctor on April 04, 2010 at 10:27 AM
Message for initial start-up (2 seconds, like normal ) and then shutting down. Since the pressure in the rail would drop as soon as the injectors began opening up if the pump stopped pumping...
Yep - may be an ECU issue?
