TwinTurbo.NET: Nissan 300ZX forum - 34 the hardest to replace, Did you replace that sensor>>
Subject 34 the hardest to replace, Did you replace that sensor>>
Posted by ZUL8TR on April 03, 2010 at 5:10 AM
  This message has been viewed 66 times.
In Reply To codes 33 34 and 35 posted by alwaysliftin on April 02, 2010 at 07:28 PM
Message and harness when you had the lower manifold off? If not and it is defective after checking the connections and ohms to be sure the sensor is bad you can do the sensor bypass. Not as good as OEM location but not bad. I believe TTer Bernie(Nova) has a bypass kit.
ZUL8TR in Orlando,FL
