TwinTurbo.NET: Nissan 300ZX forum - Ok,just read another post that says to set base idle...
Andy_M
on April 01, 2010 at 8:57 AM
Yea, that is how I set the base idle but the tech doc says:
posted by Andy_M
on April 01, 2010 at 08:31 AM
you have to disconnect the electrical connection to the IACV first, set the base idle, then reconnect the IACV. The doc on the tech page doesn't say that, and I didn't do that, so I will try that tonight and reset the base idle that way.
Andy_M
atmorris@ptd.net (home)
Changed IACV and fixed vacuum leak - now idle issue
Andy_M
12:51:02 03/31/10
Did you set the base idle after replacing the IACV? (n/m)
Eric(FL)
13:43:43 03/31/10
Re: Did you set the base idle after replacing the IACV?
Andy_M
08:19:15 04/01/10
I did, but maybe I didn't follow the right procedure.... (n/m)
Andy_M
08:21:48 04/01/10
Andy_M
08:31:30 04/01/10
Ok,just read another post that says to set base idle... -
Andy_M
08:57:22 04/01/10
Correction
Andy_M
08:16:35 04/01/10
Re: Base idle set correctly...now VERY low cold idle
Andy_M
09:50:08 04/05/10
