"Automatics should idle 50-70 rpm higher when put in neutral. The engine will tend to idle no lower that 700 rpm, so I would suggest turning the screw counterclockwise until the rpms just slight start to rise. "
My idle drops a LOT more than 50-70 rpm when I put it into R or D from Park, so maybe the right question is what could be causing the excessive idle drop ?
