TwinTurbo.NET: Nissan 300ZX forum - help! connectors and air leak!
Subject help! connectors and air leak!
Posted by randy (detroit) on March 31, 2010 at 3:49 PM
  This message has been viewed 79 times.
Message i just finished putting back together my VG30DE. i replaced the valve
cover gaskets, the TB gaskets, the plenum gasket, the idle air hoses,
idle air control gasket, balance tube o rings, all 3 drive belts, and the pcv
hoses and valves. also some vacuum line(fuel pressure reg and
dampner). i also added a pop charger. i have read that the car will run
terrible for a minute or so but my car will only stay running when the
accelerator is pressed. sometimes, not all the time, i hear a loud escape
of air coming from behind the drivers side of the plenum. also
throughout the time of me trying to find the leak(about 5 minutes) my
car backfired once.
what could be causing this leak and could that somehow have led to the
engine backfiring? any advice would be greatly appreciated as i dont
want to have to tear everything apart again.
also i have these connectors that i cant find where they go. i have spend
about an hour trying to find where they go. you have to copy and paste
the link in your address bar because i couldnt figure out how to post the
actual picture. sorry
[ http://img.photobucket.com/albums/v303/randylwjr/0331001510.jpg? ]
t=1270068331
the yellow and the white off center to the right and and the one looking
right at you off center to the left. this is on the drivers side
[ http://img.photobucket.com/albums/v303/randylwjr/0331001511.jpg? ]
t=1270068451
these two right in the middle, yellow and black. these are on the
passenger side.
i have all of the coil packs and fuel injectors hooked up and i labeled
everything but the labels fell off. it took me 4 weeks to do this.
any help would be greatly appreciated
thank you very much
randy
