TwinTurbo.NET: Nissan 300ZX forum - The idle should be perfectly smooth on a well running
Subject The idle should be perfectly smooth on a well running
Posted by Audioquest on March 30, 2010 at 12:41 PM
  This message has been viewed 96 times.
In Reply To EGR help.. posted by 2inTurbo on March 30, 2010 at 11:30 AM
Message engine. Have you run ECU diagnostics yet? I would also suggest pulling the injector connectors to see if they are corroded, as well as test them with a multimeter to see if they are in spec. If they are corroded, pull all the others with the spring clip as they tend to become that way and will keep things from operating properly. This is a good place to start to ensure good connections are present.
