TwinTurbo.NET: Nissan 300ZX forum - Am I crazy or is the bottom middle plug have a bent
Subject Am I crazy or is the bottom middle plug have a bent
Posted by 5280Z_nightstalker on March 28, 2010 at 2:47 PM
  This message has been viewed 161 times.
In Reply To blazt help posted by Paulym1111 on March 27, 2010 at 11:26 AM
Message electode? Do the steps that Dee (devil z) said. Those plugs show a lean mixture which would indicate timing. The Blazt always shows 15, you need to use a timing light.
The TPS is fine FSM says .4-.5V
Check your plug gap also but you have something more then a simple plug gap.
What kind of injectors did you buy? JECS or JEGS? I bet your injectors are bad (out of OHM, not sealed right, something).
"Do you guys put the key in "balls down", or up?" -BobbyT 10:28:19 03/06/09
tt.net
