TwinTurbo.NET: Nissan 300ZX forum - I guess a VTC solenoid could fail two ways:
Subject I guess a VTC solenoid could fail two ways:
Posted by LitlElvis on March 28, 2010 at 10:02 AM
  This message has been viewed 289 times.
In Reply To Re: No damage possible. posted by zx299 on March 24, 2010 at 05:47 PM
Message 1) fully retracted - this is the non-energized position and is used when the VTC is activated, advancing the intake cams 20°.
2) fully extended - this mode occurs when the solenoid is energized and is used when the VTC is not active.
You could verify either mode by energizing the suspect solenoid via a Conzult or by grounding their green with black stripe wire while the solenoids are connected to the wire harness. If engergizing the solenoids causes a change in idle quality for the worse, they are working as designed.
