TwinTurbo.NET: Nissan 300ZX forum - switch to the 6b 11b s, do a boost leak ,check base timing
Subject switch to the 6b 11b s, do a boost leak ,check base timing
Posted by The Devils Z on March 27, 2010 at 1:37 PM
  This message has been viewed 171 times.
In Reply To blazt help posted by Paulym1111 on March 27, 2010 at 11:26 AM
Message check a/f ratio ( will need a guage for this ) under load, and depending of the color of the smoke under boost - you need to determine if your turbos are smoking or if there is someother culprit making the exhaust smoke ..
I would clear the ECU to start self learn ...and obviously check for codes .. somewhere along this process your issue should be exposed .. if not .. do a compression test and check oil pressure at idle ..
=============Sig begins here================
The Devils Z.com
The Devils Z Pic
666 rwhp dyno
The Demon Z pic (in progress)
View Me! Disclaimer : Not Safe For Work !
