TwinTurbo.NET: Nissan 300ZX forum - Perhaps adjust TPS to ~ .42V Plugs confirm lean mixture.
jschrauwen
on March 27, 2010 at 1:12 PM
blazt help
posted by Paulym1111
on March 27, 2010 at 11:26 AM
Also, have a look here -
La-Z-Link
blazt help
Paulym1111
11:26:01 03/27/10
Perhaps adjust TPS to ~ .42V Plugs confirm lean mixture. -
jschrauwen
13:12:05 03/27/10
His ECU is showing closed TPS switch activated, its working. (n/m)
SkiFly01
13:03:25 03/31/10
switch to the 6b 11b s, do a boost leak ,check base timing
The Devils Z
13:37:51 03/27/10
also make sure you have good o2 sensors ..they should
The Devils Z
13:39:29 03/27/10
you can replace the battery gauge, and put in ...
pearlzed
16:46:30 03/27/10
PCV restrictors??
Paulym1111
19:48:34 03/27/10
Am I crazy or is the bottom middle plug have a bent
5280Z_nightstalker
14:47:50 03/28/10
