TwinTurbo.NET: Nissan 300ZX forum - no power white smoke good injectors
Subject no power white smoke good injectors
Posted by buriedlemons on March 26, 2010 at 1:04 AM
  This message has been viewed 202 times.
Message So I purchased a 1990 300zx NA a few weeks ago for cheap
from a neighbor and now I have been trying to get it running
well enough. Initially I replaced the battery and had to
replace the MAFS, which was removed for instillation into
someones 240sx. After that I was able to start the car and
can hear what sounds like a massive vacuum leak from
somewhere on the drivers side of the engine bay. Also there
seems to be no power steering it takes alot of effort to
turn I made it once around the block and back with the car
bucking and losing power over about 2500rpm. I learned how
to check my codes and did so with the ecu throwing 12 34 53
after I cleared the codes it only threw 34 53. So I replaced
the o2 sensor hoping that would clear up both but no go. I
cleared the codes and restarted the car drove around the
block and once again all three codes appeared anyway I am
just looking for some advice as to which direction to look
from here to get the car running well enough.
I was told to put new spark plugs of the proper variety and
did then when I started it, the car seemed to run smoother
except for white smoke coming out especially white out of
the left tailpipe and brownish white from the right all
removed spark plugs were black covered from fouling as was
the o2 sensor I removed not sure where to go next I did
check all the injectors and they ohm out and cleaned all of
the connectors on the coil packs and injectors, still
getting code 34 would that cause all of these or could there
be some damage done I should be looking for? Thanks for the
help.
