TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: low vacuum 30 in and 20 in at WOT. 36* timing at WOT
Subject Re: Re: Re: low vacuum 30 in and 20 in at WOT. 36* timing at WOT
Posted by Stadsport (PHX) on March 25, 2010 at 1:38 AM
  This message has been viewed 73 times.
In Reply To Re: Re: low vacuum 30 in and 20 in at WOT. 36* timing at WOT posted by blackice98 on March 25, 2010 at 01:25 AM
Message Nope, faulty fuel injector has nothing to do with vacuum. Be careful with a faulty injector though, it can lean out you A/F mixture and
cause detonation, especially at full boost.
Sounds like your smoke tester only tested the intake manifold. A boost leak tester (the one that's common in the Z community at
least) takes the place of the MAF temporarily, so you can listen for leaks in the piping connecting to the turbos and intercoolers as
well.
Also, check out this page for instructions on setting up Nissan DataScan (Click your OS under USB Driver Installation Guides):
[ http://www.blazt.biz/downloads/usbdrivers.php ]
