TwinTurbo.NET: Nissan 300ZX forum - Re: Re: low vacuum 30 in and 20 in at WOT. 36* timing at WOT
Subject Re: Re: low vacuum 30 in and 20 in at WOT. 36* timing at WOT
Posted by blackice98 on March 25, 2010 at 1:25 AM
  This message has been viewed 75 times.
In Reply To Re: low vacuum 30 in and 20 in at WOT. 36* timing at WOT posted by Stadsport (PHX) on March 25, 2010 at 12:07 AM
Message i cant get nissan data scan to connect with my ecu for some reason but this program ecutalk does connect. I have real bad hesitation at wot almost none. So the faulty fuel injector has nothing to do with the vacuum pressure?
whats the difference between a boost leak tester and a smoke tester? I made a air intake plug with a 3" pvc cap and a valve stem. I smoke tested it thru the balance tube and i did not have the throttle body's open when I did it.
