| Message |
Unless you didnt have the stock water pump pulley on, one thing that would cause the water pump to fail is the wrong belt or a overtightend belt putting too much tension on the pump bearings. Do you have all water in the system? The water gets hot, expands, evaporates and causes steam and air pockets to form. Air pockets cause the hoses to expand and over pressurizes the system. If you cannot find any leaks chances are there is air in the system somewhere.
------------------------------------------------------------ GET SOME. |
