TwinTurbo.NET: Nissan 300ZX forum - Are you doing a plenum pull? How many injectors are >>>
Subject Are you doing a plenum pull? How many injectors are >>>
Posted by ZUL8TR on March 24, 2010 at 2:40 PM
  This message has been viewed 162 times.
In Reply To injecter removal posted by Zboy17 on March 24, 2010 at 01:24 PM
Message you replacing? If just 1 - 3 suggest a dremel approach. What ever way you do it pressure test the injector(s) for no fuel leaks before starting the car. The pressure test is easy to do with a small air pump that is valved to prevent back flow thru the air pump. What you pressure test is both fuel rails with injectors. The fuel rails are disconnected at the fuel filter and the return line to the tank. Then set up a loop with the air pump to pressurize.
If doing a plenum pull here is the procedure from tech
[ http://www.twinturbo.net/nissan/300zx/tech/plenum/plenum.aspx ]
For the dremel method do a search.
ZUL8TR in Orlando,FL
