TwinTurbo.NET: Nissan 300ZX forum - It's likely not directly from the oil change
Subject It's likely not directly from the oil change
Posted by draker on March 22, 2010 at 1:02 PM
  This message has been viewed 93 times.
In Reply To Problems after oil change-Idle/throttle issues posted by bt300z32 on March 22, 2010 at 12:14 PM
Message It's from bad electrical connections under the hood. If those sensors aren't reading right sometimes, replace those first. Also it seems like half of this forum is dedicated to hesitation and stalling questions so browse around and you'll find which connectors you should pull off and clean. These connectors get the green corrosion on them and wreak havoc on the engine operation.
So, inspect, clean, grease... that should help.
