TwinTurbo.NET: Nissan 300ZX forum - Tip- With injector(s) replace always pressure test the >>>
Subject Tip- With injector(s) replace always pressure test the >>>
Posted by ZUL8TR on March 21, 2010 at 7:39 AM
  This message has been viewed 119 times.
In Reply To figured it out...i think posted by Paulym1111 on March 20, 2010 at 12:34 PM
Message fuel rails after they have been isolated from the filter and the return to the tank - B4 starting the engine. Prevents possible fuel hydro lock and gas in the oil and a bunch of wasted time.
Note if you use a compressor air pump to pressureize the fuel rails have a shut off valve on the compressor output side so it can be shut off when pressureized to prevent backflow of air theu the air compressure rings which could easily be diagnosed as a fuel leak.
ZUL8TR in Orlando,FL
