TwinTurbo.NET: Nissan 300ZX forum - Re: head gasket
Subject Re: head gasket
Posted by draker on March 21, 2010 at 1:20 AM
  This message has been viewed 130 times.
In Reply To head gasket posted by mlewis300 on March 20, 2010 at 10:55 PM
Message Well, is that the only reason you think you have a blown head gasket? Are you mysteriously losing coolant?
You should either run a compression test, or leak down. You can also do a power balance by pulling the coil plugs one at a time to see which one is under-performing or not performing.
If you feel comfortable doing these tests, then that's a start. Doing the head gaskets is going to be a big job. It's do-able if you have some experience. But it's considered a major job.
