TwinTurbo.NET: Nissan 300ZX forum - Re: Clutch engagement point varies-bleed or adjust pedal first?
Subject Re: Clutch engagement point varies-bleed or adjust pedal first?
Posted by draker on March 18, 2010 at 11:44 PM
  This message has been viewed 86 times.
In Reply To Clutch engagement point varies-bleed or adjust pedal first? posted by hunterdg on March 18, 2010 at 06:05 PM
Message Sounds like it could be leaky master cylinder pistons. The new clutch probably takes more pressure to disengage the clutch than the old one right?
If the pedal still feels tight, then it probably doesn't need bled, and the adjustment would just move the engagement point like you mentioned.
