TwinTurbo.NET: Nissan 300ZX forum - A faulty relay did cause my starter to act weak like >>
Subject A faulty relay did cause my starter to act weak like >>
Posted by ZUL8TR on March 18, 2010 at 4:11 PM
  This message has been viewed 302 times.
In Reply To Bad starter relay? posted by OkieTT on March 18, 2010 at 11:10 AM
Message a low battery. Confirm that the starter is good by jumping it directly from the battery + post to the solinoid lead wire that was disconnected. With the key in the on position the car will start smartly if the starter OK. This test bypasses the relay so that is the next suspect item. Only use a Nissan relay or else the connector will not plug in with the after market relays.
ZUL8TR in Orlando,FL
