TwinTurbo.NET: Nissan 300ZX forum - not only temp gauge freaking, so am I
Subject not only temp gauge freaking, so am I
Posted by FASTESTZX on March 17, 2010 at 12:40 PM
  This message has been viewed 92 times.
Message Posted this yesterday
"I put a new alternator in and after I started the car the
temp gauge stayed at dead cold for a long time. then it
started climbing to normal and then on up and up to just
under very hot top of gauge. Slowed down and the temp
dropped a bit. turned engine off and waited a few minutes
and the temp gauge read much cooler than it would take for
the engine to cool.. but I still am thinking the engine is
over heating so I take it home. I go and replace both temp
sensors on the goose neck and I'm still having temp gauge
problems. I still believe the gauge is malfunctioning but
it is unnerving that it is pegged on HOT. Any ideas how to
fix?"
Well I read all th temp gauge posts and how erratic and unreliable they wer so even though it bothered me Im driving to work this AM and The temp gauge goes up and I'm cruising along fine when POW coolant is blown through the air purge plastic plug on top right side of radiator!
What is causing this? It has a new water pump, radiator cap 16lbs, a new thermostat, new temp sensors on gooseneck both the gauge and ECU sensors. what could have caused this???
Need help.
