TwinTurbo.NET: Nissan 300ZX forum - I'm not sure it's the best idea but..
Subject I'm not sure it's the best idea but..
Posted by z32drifter on March 14, 2010 at 2:06 PM
  This message has been viewed 64 times.
In Reply To How much do I need to shorten the front stock coil springs? posted by DonCig on March 14, 2010 at 11:00 AM
Message The lower the car goes the quicker it gains camber. I would
expect if you are on stock springs it would take aprox 1"
reduction in ride height to gain the camber you are looking for.
I'm going to guess there is some good reason you are keeping
the stock low rate springs. You are going to want to cut both
front springs and then reset camber with the upper control arm.
Just cutting 1 spring will affect your corner balance. Make sure
you cut the coil properly so it will seat in the lower mount.
3rd gear might not have been the best idea.....
