TwinTurbo.NET: Nissan 300ZX forum - Does the injector have +12v present? -- it should. If that
Subject Does the injector have +12v present? -- it should. If that
Posted by jzack on March 14, 2010 at 11:27 AM
  This message has been viewed 62 times.
In Reply To please help no pulse at no#1 injector! posted by bubba14 on March 13, 2010 at 08:28 PM
Message is OK you'll need to check the ECU connector to verify it's seated correctly on the ECU. Would also need to check whether or not there's continuity between the ECU connector and the connector in the engine bay (pin on injector plug that DOES NOT have the +12v). AutoFAQ section has color coded wiring diagrams with wiring color codes. Wire continuity can be checked using a digital voltmeter.
If there's no continuity you may have to run another line from the ECU to the injector connector....
