TwinTurbo.NET: Nissan 300ZX forum - How much do I need to shorten the front stock coil springs?
Subject How much do I need to shorten the front stock coil springs?
Posted by DonCig on March 14, 2010 at 11:00 AM
  This message has been viewed 92 times.
Message I want to grind/cut/compress/shorten my stock left front coil spring by a (?) cetrtain amount to cause the left front suspension to change its camber geometry by 1 degree negative. Any advice as to how to make this small but needed change in spring length?
Thanks,
DonCig
Denver
For those that want to know why; I have SPL adjustable upper links and when both are set to the most inward setting I have the following camber measurements; minus 2.6 degrees on the left front; minus 3.6 degrees on the right front. I am trying to bring the left front setting to minus 3.6 degrees to match the right front. I track the car, so no comments on the agressive settings please.
"Racing is Living; everything else is just Waiting."
