TwinTurbo.NET: Nissan 300ZX forum - 2 problems. Fuel pump Buzz and a/c pod display out.
Subject 2 problems. Fuel pump Buzz and a/c pod display out.
Posted by DKaway on March 14, 2010 at 8:03 AM
  This message has been viewed 85 times.
Message Fuel pump:
I just completed a sucessful rebuild by ILGO, Great guy!
he rebuilt my engine and it started up on the first try.
After he left, I never had the time to put the body parts back on, so I would start it up and let it idle about once every two weeks. Then I didn't start it for a while.
I went out to start it up, and nothing. long story short, I don't notice the fuel pump buzz.
I checked all the fuses, fusible links and relays. they are all good (tested with ohm meter). I know the fuel pump is good, I was replaced with a brand new fuel pump.
I ran the ECU diagnostic and no codes came up.
just to let you know, I turn the key to ON, to listen for the fuel pump buzz behind the driver/passenger and I don't hear it.
What my next step?
The a/c pod:
I know it works, i posted about this before. It would not show the numbers and then one day it came back (it was intermitten).
Not it is out again, so I think it has to be some other thing because the front wipers do not operate either.
When the a/c pod disply is out, the wipers don't work either.
What is my next step?
Thanks guys
