TwinTurbo.NET: Nissan 300ZX forum - Here is a way but harder. Place # 1 cylindere at TDC>>
Subject Here is a way but harder. Place # 1 cylindere at TDC>>
Posted by ZUL8TR on March 14, 2010 at 7:41 AM
  This message has been viewed 73 times.
In Reply To Any other way to check timing? posted by Nikknakz on March 13, 2010 at 05:25 PM
Message of the compression stroke NOT exhaust stroke. This requires a means to find the true TDC of the piston motion and this is usually done with a depth dial indicator in the spark plug hole. Once located place a mark on the UD pulley opposite the stationary pointer on the engine. Then measuring the circumference of the UD pulley with a cloth tape at the radius where you marked the TDC you can calculate 15 degree of a circle by proportion x the circumference.
I.E. Inches of Circumference x 15/360 =
inches of 15 degrees of arc.
Then measure this arc distance along the pulley from the TDC mark you determined (use the distance marked on a piece of paper to get it to contour the pulley). If not sure of crank rotation, to keep it simple you can place a 15 degree mark on each side of the TDC mark and when you place the timing light on the pulley one of these will be correct and it will be obvious when you adjust the CAS.
Might want to consider getting another UD pulley or put the OEM back on?
ZUL8TR in Orlando,FL
