TwinTurbo.NET: Nissan 300ZX forum - Re: Steering knuckle rubbing new rack and pinion
Subject Re: Steering knuckle rubbing new rack and pinion
Posted by ttz'in (NorCal) on March 14, 2010 at 3:23 AM
  This message has been viewed 433 times.
In Reply To Steering knuckle rubbing new rack and pinion posted by cooler17 on March 14, 2010 at 01:37 AM
Message Someone here will have the answer.
Correct, no Dremels or shaving parts.
Assuming road and steering wheel were all centered at removal, dust boots equal deflection, steering wheel centered.
Knuckle in right side up ?
Make sure top bolt in lower joint fits into cut-out on lower shaft threads
Lube shaft sliding surfaces (no pun) w/ PB,WD40 etc, loosen steering clamp and rack bolts and reset.
See FSM if possible for replacing rack.
