low idle posted by mlewis300 on March 13, 2010 at 08:18 PM
3) Make sure your plugs are gapped to 0.035" AND that you are using the corrent PFR6B-11B (with the B on the end). If it doesn't have the B on the end, it is not the projected tip plug that must be used in the TT. 4) If all is well, you can open the idle screw a bit to bring your idle up to ~850. Open it about a 1/4 turn at a time and give a few seconds from turn to turn so that the idle will stabilize.
