TwinTurbo.NET: Nissan 300ZX forum - first replace the WTS (i call it CHTS from my z31 days)
Subject first replace the WTS (i call it CHTS from my z31 days)
Posted by surfer31337 on March 12, 2010 at 9:38 PM
  This message has been viewed 195 times.
In Reply To not sure if bad wastegate, solenoid is causing hesitation posted by blackice98 on March 08, 2010 at 12:30 AM
Message which seems pretty obvious. next adjust the TPS to 0.40v - 0.50v at idle and +3.90v at WOT (if u can't get make those numbers then replace it). then clear the codes and go for a test drive.
i would forget about the wastegate solenoid. u mentioned a blowoff valve, which was not designed for the Z32, and IMO could easily be causing your symptoms.
