TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Prob something to do with alt+idle pulley....more
Subject Re: Re: Prob something to do with alt+idle pulley....more
Posted by FASTESTZX on March 12, 2010 at 7:09 PM
  This message has been viewed 64 times.
In Reply To Re: Prob something to do with alt+idle pulley....more posted by FASTESTZX on March 10, 2010 at 06:04 PM
Message ::Think how the system works as a rotating unit. All three
:are dependent
::upon eachother to work. If alternator is noisy it has to
be
:the rear
::bearing that is housed in back of alt. Its the only thing
:that can cause
::friction due to wear thus making a noise. That said the
:bearing rides on
::the rotor and stator shaft if that shaft is pulled to hard
:at an angle it will
::put that rear bearing in a bind and there is prob.
Question
:is what is
::pulling on the alt pulley to do that? So typically its the
:idle pulley because
::its the weakest link in that system. That pulley should
:have no wiggle
::movement nor should it have a rough roll to it. But,
:anumber of other
::issues may be at play...the alt bracket, the actual bolt
:that hangs the
::alt...is it outta wack. Like u said fan clutch ..does it
:seem to work ok. Just
::start checking but usually its that damn silly pulley!
