TwinTurbo.NET: Nissan 300ZX forum - well, I don't think it's the MAF
Subject well, I don't think it's the MAF
Posted by fantomZ(OH) on March 12, 2010 at 12:12 PM
  This message has been viewed 80 times.
In Reply To Re: do you have a copy of a chip in your ECU? posted by nismo360 on March 12, 2010 at 11:38 AM
Message as I have also experienced a failing MAF. It never caused the car to not shut off but would limit the RPMs to somewhere around 3K and would basically make the car un-drivable.
What do you mean all the lights work with the Key turned off? Like you can turn on the interior lights? Headlights/ Taillights? If so, this is normal and has nothing to do with the ignition.
I never got any codes when my car wouldn't shut off.
Here's what I would do. Try to find someone near you that has a good known MAF (although I don't think that is the problem) and ECU and spend an hour swapping them out. No money lost and it should either pinpoint or rule out those two things as a problem.
Good Luck,
-Adam
1990 Stage IV Twin Turbo.
My fast car.
