TwinTurbo.NET: Nissan 300ZX forum - short answer: yes
short answer: yes
canyoncarver
on March 11, 2010 at 8:55 AM
can I avoid bleeding the clutch slave after installing cmc
posted by mossyoak
on March 09, 2010 at 11:26 AM
You should bleed your clutch and brakes every year or so anyways. Do you really want to install new cylinders and leave crappy old, moisture filled, fluid in the lines?
mossyoak
11:26:27 03/09/10
The only way to not bleed the system on a replacement>>
ZUL8TR
12:02:17 03/09/10
There is a way to try - if if doesn't work can always
jzack
20:48:08 03/09/10
thanks, will do.
mossyoak
08:29:02 03/10/10
Unless really careful here a bleed of the slave and the >>
ZUL8TR
06:49:58 03/11/10
short answer: yes -
canyoncarver
08:55:06 03/11/10
