TwinTurbo.NET: Nissan 300ZX forum - Prob something to do with alt+idle pulley....more
Subject Prob something to do with alt+idle pulley....more
Posted by SilverSlickTopTT on March 10, 2010 at 12:56 PM
  This message has been viewed 90 times.
In Reply To Alternator Belt/Pulley issues posted by pocheeyo on March 09, 2010 at 12:55 PM
Message Think how the system works as a rotating unit. All three are dependent
upon eachother to work. If alternator is noisy it has to be the rear
bearing that is housed in back of alt. Its the only thing that can cause
friction due to wear thus making a noise. That said the bearing rides on
the rotor and stator shaft if that shaft is pulled to hard at an angle it will
put that rear bearing in a bind and there is prob. Question is what is
pulling on the alt pulley to do that? So typically its the idle pulley because
its the weakest link in that system. That pulley should have no wiggle
movement nor should it have a rough roll to it. But, anumber of other
issues may be at play...the alt bracket, the actual bolt that hangs the
alt...is it outta wack. Like u said fan clutch ..does it seem to work ok. Just
start checking but usually its that damn silly pulley!
