TwinTurbo.NET: Nissan 300ZX forum - swap a coil pack from a working cylinder
Ahmed (Chicago)
on March 10, 2010 at 8:02 AM
I have found posts on how to check for bad injectors>
posted by BrianTT(Tpa,Fl)
on March 10, 2010 at 07:45 AM
into the cylinder that is misfiring...if it doesn't fire, then that tells you it is something else (most likely an injector if you still have old style injectors)
Professional Photoshoot of my Z
BrianTT(Tpa,Fl)
07:45:29 03/10/10
swap a coil pack from a working cylinder -
Ahmed (Chicago)
08:02:17 03/10/10
coils should ohm around .7 (n/m)
Paulym1111
08:08:26 03/10/10
Where do I check? At the coil or ECU? (n/m)
BrianTT(Tpa,Fl)
08:11:13 03/10/10
check the ohm's from the pins on the coil pack itself..
Paulym1111
09:40:01 03/10/10
Thanks for the info! (n/m)
BrianTT(Tpa,Fl)
09:58:55 03/10/10
I think it's better to actually run them and look for a
jzack
18:55:44 03/10/10
