TwinTurbo.NET: Nissan 300ZX forum - Id start w/ double checking all connectors then..
Subject Id start w/ double checking all connectors then..
Posted by SilverSlickTopTT on March 09, 2010 at 10:58 PM
  This message has been viewed 63 times.
In Reply To Car sat for about a year! Was running fine before this> posted by BrianTT(Tpa,Fl) on March 09, 2010 at 08:02 AM
Message After checking all the connectors. Id check resistance on each coil pack
then each injector. If all ok pull cas out turn ingition on(no starting it)
turn the shaft of the cas and ull hear as your turning each injector will
click check em. Quick to check and eliminates three major things. Then
time it with a light. If u dont have the tools to do ot runa self diagostic
test. All u need for that is a 10mm socket and a flat screw driver. So not
bad. Good luck with it!
