TwinTurbo.NET: Nissan 300ZX forum - The only way to not bleed the system on a replacement>>
ZUL8TR
on March 09, 2010 at 12:02 PM
can I avoid bleeding the clutch slave after installing cmc
posted by mossyoak
on March 09, 2010 at 11:26 AM
of the CMC is to do it without getting air into the system. I don't see how that can be done, so bleeding is required at both the CMC and the SC. A tip on the CMC is to bench bleed it to remove as much air as possible.
ZUL8TR in Orlando,FL
mossyoak
11:26:27 03/09/10
The only way to not bleed the system on a replacement>> -
ZUL8TR
12:02:17 03/09/10
There is a way to try - if if doesn't work can always
jzack
20:48:08 03/09/10
thanks, will do.
mossyoak
08:29:02 03/10/10
Unless really careful here a bleed of the slave and the >>
ZUL8TR
06:49:58 03/11/10
short answer: yes
canyoncarver
08:55:06 03/11/10
