TwinTurbo.NET: Nissan 300ZX forum - My Guess
Subject My Guess
Posted by Greg D. (Specialty-Z) on March 09, 2010 at 9:41 AM
  This message has been viewed 66 times.
In Reply To new RPS clutch pressure plate making "pop" noise posted by surfer31337 on March 06, 2010 at 10:49 PM
Message The transmission front cover has a tube the T.O. bearing collar slides on........more then likely the tube has a ridge worn in it that the T.O. bearing collar is getting caught on.
This was really common to find in the early 240Z cars.
The wear occurs over time when a T.O. collar goes dry and a missing or torn clutch fork dust boot will alow the damage to occur quicker from dirt and water being allowed to enter the bell housing area.
A new pressure plate will release in a different area than an older worn pressure plate and this will cause the T.O. collar to operate in a different area of the front cover tube.
When the T.O. bearing collar moves into the area of the ridge, it will cause the collar to get stuck for a moment until the pressure forces the collar past the ridge causing a "POP".
