TwinTurbo.NET: Nissan 300ZX forum - ZUL8TR is spot on again
Subject ZUL8TR is spot on again
Posted by Zarcasm(Hfd, CT) on March 08, 2010 at 7:56 PM
  This message has been viewed 96 times.
In Reply To Are you referring to the white dot on the pully not >> posted by ZUL8TR on March 07, 2010 at 07:34 AM
Message I recently replaced my timing belt. I had all the stars, dots, and lines aligned perfectly and then started rotating the crank by hand. It wasn't long before the lines and dots were far apart... and that's just cranking the engine by hand. Check the cogs between the dots, you're probably aok.
Please update your profile.
Zarcasm(Hfd, CT)
view My Technical posts (click here)
view My General posts (click here)
